Incriminator Audio Death row D1 12's
HomeGrown
michigan
8.5 out of 10 they are used and are still mounted
light paint smuges on basket
had these since April
8 Spoke Black Cast Basket
3” 4 Layer Flat Wound Aluminum Voice Coil
Dual Black Progressive Spiders with Woven Tinsels Injected Pulp Matrix Fiber Reinforced Cone Multi-Layer Foam Surround Triple Stacked Magnets with Black Nickel Finish Interlocking Aluminum Spider Spacer Assembly CILD - Center Interlocking Dustcap ADC - Air Driven Cooling Nickel Plated Push Terminals Wrap Around Rubber Gasket 1000 watt RMS Rated RMS power Handling: 1000 Watts MAX power Handling: 2000 Watts ohm Load: Dual 1 ohm
FS: 37Hz
Qms: 5.78
Qes: .49
Qts: .44
Mms: 205 g
Cms: .09 mm/N Sd: 480
Vas: 29 L
Spl: 86.9 dB, 1w/1m
BL: 16.4 TM
XMAX: 24MM
Outer Diameter: 12 3/8" Mounting Diameter: 11 1/8" Mounting Depth: 7 5/8" Displacement: .15 cu. ft.
375$ plus actual shipping
exact shipping to be paid by buyer
will get new pic if needed with username if needed
will also concider trades and add funds if need be
Tartanic HDs
DD's
PSIs
I like my DRs but want to try other brands out .
is that price for 2? it says 12's but it didn't say 2 or what and what the price is for.
yes both
I think this is a steel myself. no hurry to sell cause I love these things
I have personally heard these things and they slam!!!!! great deal too cheap in my opinion.... why does everybody sell the stuff i want after i buy something new??? lol
They all say they are in stock but they aren't. Just like my SSA Zcons and Evils were "in stock" but had a super long build time.
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Looks good to me. Incriminator stuff looks high quality. The power numbers with subs and amp match well.
HomeGrown
HomeGrown
michigan
blobb454
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
