Incriminator Audio Death penalty 12s
97maxima
Loud Trunk?
1. Product:
IA Dp-12s
2. Specs:
Dual 1 coils, dual lead upgrade
Black Cast Basket
3" 8 layer Flat Aluminum Voice Coil
Triple Black Progressive Spiders with Woven Tinsels
Non-pressed Kraft Fiber Reinforced Cone
Double Layer Foam Surround
Triple Stacked Magnets with Black Nickel Finish
Interlocking Aluminum Spider Spacer Assemble
CILD - Center Interlocking Dustcap Design for Easy Field Recones
ADC - Air Driven Cooling - Six Column Vents for Max Motor Cooling
Silver Push Terminals
Wrap Around Rubber Gasket
1500 Watt RMS Rated
FS - 44 Hz
RE - 4 ohm Series
QMS - 8.67
QES - .42
QTS - .40
MMS - 240.58g
SD - 480 cm^2
Vas - 16 L
SPL - 90.1
BL - 21.4
Xmax - 28 mm
3. Description/Condition:
Used for testing and 2 shows, broken in but still in minty condition. Rated for 1500 rms but will handle alot more clean power
4. Price: :
600 for the pair plus shipping
5. Pictures:
IMG_20130306_123122 by Mr.97maxima, on Flickr
IMG_20130306_123151 by Mr.97maxima, on Flickr
IMG_20130306_123105 by Mr.97maxima, on Flickr
97maxima
Loud Trunk?
97maxima
Sc
97maxima
