Incriminator Audio 20.1 Vs Crunch goundpounder 3000d
i have read alot about the hifonics brutis amps, and crunch amps being overrated. now they are great amps for the money. not taking anything away from them. but they are not built like the ia amps. (they don't cost near as much as ia amps either)
i understand what you are saying, but maxxsonics also makes MBQ which are not overrated, but in fact underrated. And yes the crunch and Hifonics are overrated, but when you get to the gp3k, thats a completely different animal. It is a very solid amp.
i have read good things about the gp amps and have hooked up a couple of them. i still say if i were spending the same amount of $$ i would take the 20.1 hands down. i know what the amps will do and will stick with ia. i have used other brand amps and have always come back to my 40.1s. i have put up better #s w/ ia amps than with other brand amps twice the power.
This:
Ok guys' date=' here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT!
This is from a quote on the termpro fourum.[/quote']
wow would love to know how much rise my box is getting.with my alt and batt setup now im not dropping below 14.0 at all.how can i check box rise if i may ask
GP is a different story so end that argument.
The GP will produce more power under the same conditions as the IA 20.1 and a lot more than the Hifonics 2610 and the rate of the difference in power will increase as you increase the volts. The GP3k is an absolute beast. It has been compared to the 40.1 and did quite well but it can't compare to something meant to do 4000+ all day everyday. It's an excellent budget 3k amp. You could also get 2 MBQ 1500's and get 3k or more //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
riddla
riddla
nf
Ridintwo6s
