In Need of Sub Box Design
SethPhillips
I'sa Playa
Decided to run my 2- 12'' Fi ssd's in my 99 acura integra hatch.
i want the sub's and the port to both face the tail light's.
i listen to mostly rap, hip/hop, and r&b everyonce in awhile some hardcore speed death metal.. but that's only on monday morning's... to start the week off right;)
if someone could whip me up a cut sheet to give me something to do this saterday at work..
thanks
seth
my trunk dimensions:
From the back of my seat to the vary back of my trunk. 26" deep
lowest point of wheel well to other wheel weel 30'' wide
15'' tall
sub spec's:
Fs: 27.0 Hz | 26.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.60 | 4.71
Qes: .52 | .49
Qts: .47 | .44
Mms: 192g | 201g
Cms: 0.18mm/N | 0.18mm/N
Sd: 480cm^2 | 480cm^2
Vas: 58.7 l | 58.7 l
Spl: 85.3dB 1W/1m | 85.3dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .8-1.6 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
thanks
seth
p.s. i will paypal $5for a cut sheet of the best design i allso would like it to be braced internaly so there will be no box flex.... like my last box...
I think I can get something to you within a day or so as I'm kind of busy today.
I own a '99 Integra hatch as well and I think I know my way around enclosures for them. Send me a PM if you want me to crank something out for you.
Seth, check your pm's please.
will do
yea if you could man that be kick ***
ygpm
I could do one in less than 5minutes... but I have to shower and leave for work...
nG
if you could do it later.. no big rush.. i allways have sunday off.
thanks
nG!!!
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
