in need of help with building a box!!!
Originally posted by RICKEYANDAMY i need to know what cubic foot to build a vented box for 2 12 inch audiobahn flame q's. if anybody know's the size and dimensions that i should go with please feel free to post your ad on here.
I COULD give you a whole lot of help, since I have the same subs in a 7 cu ft ported box, but why would I when you were such an ass clown? Maybe an apology would be nice.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by RICKEYANDAMY sorry homes. so what size amp do you have pushing them?can you draw up a box for me and e-mail it to me?if so i would appreciate it.
I have an Audiobahn A18001D amp running to them at one ohm, each sub is seeing ~950 watts, if not more. Here are the specs on my box...
Construction Material = 3/4" MDF
Box Height = 20"
Box Width = 36"
Box Depth = 20"
Number of Ports = 1 (Slot)
Diameter of Ports = 18.5" x 4"
Length of Ports = 23"
Port Area = 74 square inches
Box Volume = 6.83 ft^3
Box Tuning = 35.85 Hz
WinISD Estimated Peak SPL = 37.5 Hz
WinISD Estimated Peak Port Velocity = 28.62 m/s @ 35.4 Hz
Originally posted by Trixter I don't know the history, but it's amazing what a simple apology will get you.
We simply got off on the wrong foot. No biggie. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by snova031 WinISD Estimated Peak Port Velocity = 28.62 m/s @ 35.4 Hz
Hmm.... is that velocity at the 950 watts enterend into the 'signal' thingy?
I'm trying to see what I get for my subs and have 2.something at 1 watt in there.. then up to ~35 m/s at 500 watts.. is that right? and if so, what is the upper limit I want on velocity so it's not audible?
772
787
RICKEYANDAMY
RICKEYANDAMY
MORGAN CITY,LA
Savant
    May 23, 2024
    May 22, 2024
