in an active system: morel elate 602 components vs comparable 3 way?
DuoGoober
i'm looking at the morel elate 602s comps for my system but then i started thinking that wouldn't a really really good 3 way speaker set sound better than an excellent component set?
are there a cheaper pair of 3 ways (if not morel then preferably focal) that will still sound as good or better? would the 3 way morel virtus or focal p165f3 sound better?
i realize id probably have to get another amp which is another thing but what are the the arguments for and against an expensive 2 way vs slightly lower end 3 way system?
the rest of the system consists of a mosconi 4to6 dsp and go with 2 evo10s powered by an arc xdi 1100.1
thanks for any advice!
Your 4to6 DSP only has 6 channels for output. That means you're going to need another active crossover to further divide the signals as you will have 3 pairs of speakers plus the subwoofer for a total of 7 channels.
You could use the 4to8 or chain in a second 4to6 for more channel control.
Until this handled there is no need to look at most 3-way components. However, there is a number of options by CDT Audio that can have active midbass woofers and passive mid+tweeter pairs, powered by 4 amplifier channels. Do you have $600-700 to spend now?
thanks for the reply! nothing's been purchased yet so i can ask the shop about doing the 6to8 and 3 ways instead of the fancy components. gives me something to think about though. thanks again.
DuoGoober
DuoGoober
sf bay area
DuoGoober
