I'm Thinking About Getting A Big Boy Interfire Amp...
there's pretty much everything about it
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Mounting Depth - 12.75”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 10.5”
Motor Depth - 5”
Basket Depth - 7.75”
Displacement - 0.24 cu. ft.
Weight - 72 lbs.
aCer_209
aCer_209
Reno, NV
BigOso
BP1Fanatic
BP1Fanatic
