How do I go about choosing the correct size isolator for my setup? I'm currently running two air compressors and 2 amps totaling 2000 watts. HELP! The isolator that I'm looking at is the Stinger SR200, but i'm not sure if this i sufficient. TIA
uh, why? just wire up your shit in parallel, either way the load on your alternator wont be much different. How many batteries do you have to start with?
I'm looking to add a second battery. It would be pretty smart to add an isolator just so the main starting battery doesn't drain from the audio/compressors running while the car is off. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
I guess //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif if you have all that stuff in the first place, you should be running multiple batteries in parallel banks already. Not that id know about anything like that //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
