I'm inFInitely Baffled.
yeah those tc9's are beast //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif why dont u throw ur hybrid in there? it should be nicer than that pos tc9 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Did you put the camping pads between the door panel and the door frame? I think I have some rattle pad I used for my Accord doors sitting somewhere in my garage. If you want to give it a shot and see if it makes any improvement, you can feel free to try it out.
The camping foam is too thick to put between the door panel and frame. I put some ensolite on parts where the door panel meets the frame.
What I think is that I made more rattles with my treatments //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif I glue carpet to the panel and then resin'd the carpet. I think some of the carpet wasn't glued to the panel well and is a little loose causing some rattles. I think I might just all the rage gold I have left and body fill the back portion of the panel on top of the resin'd carpet. Hopefully that'll stiffen everything up and stop the rattles.
I might just try that Hybrid rl-p/Fi sub in there. tomorrow maybe. For $60, that tc9 is far from a POS. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
actually u basically stole it from me cause niether me or lev has seen payment yet //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Ah...well if it doesn't give you the results you are looking for, let me know. You can always try out the Rattle Pad, I found them //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I tried to spray expanding foam and silicone in every spot I could think of, too, and it still didn't work. I'm pretty sure it's because of voids between the resin'd carpet and the doorpanel. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
One good thing is that I got the area between the doorpanel and the baffle sealed up pretty good. I just have to seal up more areas now. I felt some good air moment from certain spots during some goooood midbass excuuuuuurshun
rear deck?
take out back seats. then side cushions, unscrew center brake light, then unscrew rear deck panel. simple, for my car at least. Some cars required the c-pillar panels to be removed.
i think that's my car, damn
you need to take out the c-pillar panels to do expanding foam anyways.
I thought I finished sealing everything up, but when I played the sub with the c-pilllars bare, I could feel a lot of air coming from them. My trunk was practically a huge ported box
in other words: quite being lazy
James Bang
Hand/Ear Coordination
James Bang
James Bang
