Im going with eDead, which one
I put 3 layers of the edead v2 on the inner and outer panels of my doors on my monte carlo earlier this year and havent had a problem. Made sure everything was clean and used a heat gun to help with the curves. So far its been great.
But then again say if u do 3 layers of b-quiet 45 mills thick thats 135mills thick with 3 layers say you are doing a 5x4 section so 60sq feet used of daedener and its 135 mills thick, well with raamat its 60 mills thick use two layers only 40sq feet used and its 120mills thick. Since raamat is prob thicker than the advertised 45mills thick b=Quiet which is really like 40 mills thick its the same mills with 2 layers of raamat vs 3 layers of b-quiet. Its also not a asphalt based deadener and everyone loves it. and its around the the same price as b-quiet but its 62 compared to 100 sqft but rember you only need 2/3's of raamat as fattmat deadener.
Just like your doors say they are 3x2 roughly six feet per layer with fattmat i would do 3 layers so suuposly 135 mills prob closer to 120-125 mills thick, so roughly 18 sq feet well with raamat 2 layers will be 120mills thick and only need 12sqfeet. So you will use 1/3 less deadener with raamat and not spend more time applying a 3rd layer.
the edead v1 which is the same thing as the 45 except the 45 is rubber butyl and the v1 was rubber asphalt. It stayed in the middle of the pack and for $50 which is roughly $80 cheaper than the others that are close i think im going to go with that.
If you are going with only one layer then dont buy cheap, cheap stuff thats not thick is made to put 2-3 layers or more since its not thick and not great stuff, get some dynamat or secondskin something liek that for only one layer application
Buy the cheapest eDead that ED sells. Install it exactly as recommended to fulfill your obligation as a would-be seeker of deadness. But, at the same time, take twice the amount you paid for it and put in your savings account as a security of sorts. Quite possibly, you will need it in the future when you realize that the "deadener" you thought you invested in was ineffective, and therefore, a waste of your money and time.
However, you could be one of the lucky few who actually acheive a missleading positive effect of "mass loading" (ie sticky stuff sticking to vibrating things) which is most likely to carry over to infecting a car audio forum (perhaps this one as it's leading the rest with dispicable ancedote) with unscientific and unvaled posts that do nothing more than propagate the guise that imiatation garbage like eDead products really do work.
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
BlkCamSS01
BlkCamSS01
House Springs, Mo.
Anthony Collova
