I'm Doing Designs BUT with conditions...
If you can do it yourself then don't bother this guy. He said only 2 designs so let ppl who really need it get them. Thats my problem. I needed a design for a box im building for my car this week. I design also, so did i ask him to do it?? No I did it myself.
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif shut the fuck up
Lol gtfo SMD brah. Id pay 5 bucks for any box
Hahahah i could but i would rather the respect over money ^_^
x2, I would post your previous boxes(designs) to show your work and experience
Here ya go, look at my albums ^_^ the ones that look ebtter are my newest designs.
ENCLOSURES pictures by kingtube69 - Photobucket
Enclosure designs pictures by kingtube69 - Photobucket
King....seriously.....charge like 5 bucks, youd still be one of the cheapest designers out there. Money is good.
Hahaha yeah like i said above respect //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
max dimensions:depth35, height16, length35sub: 15" Rd heavyweight v2
amp: something 3k+
car-2000 daewoo nubira
tuning preference-33
Im only designing people enclosures if your serious about it, do you have an amp? if not yet, please get the amp then ask me .
I need a horn loaded series tuned 6th order for 2 shocker sig 12's on 7k each what can you do?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
MAXIMUM DIMENSIONS (MOST IMPORTANT)
- What subs and how many
- What amp/s
- What Car
- Tuning Preferance
48"width max
30" depth (can be larger/smaller whatever)
17" high
2 premier champion pro 12" subs
1 hifonics hfi 2000d
honda accord
tuning pref: 32-36 hz
this is going to be a backseat box, and i'm planning on mounitng the amp to an amp rack on the back of the box, facing into the trunk
if you can do it, thanks alot man i'd appreciate it
- MAXIMUM DIMENSIONS (MOST IMPORTANT) see below
- What subs and how many 4 Emenince 15" Pro
- What amp/s 1 Blade Audio 1001MS
- What Car 2002 Voyager
- Tuning Preferance 22-29hz
Whats most important is that I have either a 24db linkwitz riley time aligned rolloff or a sloped and balanced 24db 6th order butterworth rolloff. 12 or 18 wont work. Need the VAS and all internal dimensions to fit less than 15CF no isometrics. The whole van can be used so size isnt really an issue for the install.
sub = I have a 12'' dc lvl 4
amp = AQ1200d
If the sub isn't going to fit this type of build, or you think theres a better sub for the job, then just let me know w/e it is. I'd be willing to spend around $400 on a sub.
car = 2002 mazda protege sedan
Any tuning between 15-20hz is fine
i'd like the high end to be anywhere between 40-60 hz, around 60hz would be great but if the space won't allow for that then its ok if its below that.
I'd like a 4th order bandpass, ported into the cabin through the rear deck, trunk will be sealed off.
The sealed camber will be in the spare tire well, the driver will be mounted on an angle; maybe about 45 degrees. if you have a better idea just let me know.
above the spare tire well I have:
L x H x D
28'' x 18'' x 14''
Between the box and the rear seat, there is more space with these dimensions:
28'' x 16.5'' x 3''
The spare tire well has a hump in the middle with a circumference of 44'', height of about 4''. according to my calculations it takes up about 0.4 cu ft. its almost a circle, but its a little flat at the bottom. I can get pictures if you want.
the spare tire well itself has a diameter of 25'', height of 7''.
In the max height (18''), you have to factor in 3/4'' for a floor of MDF.
If space is needed for the sealed chamber in the spare tire well, you can raise the height (which will affect the max height of the rest of the enclosure unless you make it a step-design).
For the spare tire well, you should subtract about an inch for padding/soundeadening/fiberglass. This will increase the size of the center hump by about .5'' and the outer circle will be about .5'' smaller.
I have a 6x9 speaker hole in the rear deck, but if I have to I can use a sawsall and cut through the sheet metal in the rear deck to make it however big you want the port into the cabin to be.
In front of the box (the very back of the car/trunk where the lid opens) there will be about 17'' of extra space, and to the right side of the box there will be about 8'' of space. I'd like to keep this for trunk space, but if the enclosure needs more space, I can take some space up.
The port into the cabin will need to be higher than the 'max height' (18''). the max height for the box accounts for metal bars on the top of my trunk. the port into the cabin can even exceed into the cabin, I have to measure this but it might be able to be up to about 25''-30'' high.
all measurements are in inches, not drawn to scale.
Yeah, its pretty crazy, but I'm completely serious about it.
Right now i'm fiberglassing my entire interior (dash, door pods, everything plastic). front stage is a zed kronos powering a set of hertz MLK 165 comps.
I'm 100% serious about this. I'd be willing to pay for the design upfront.
sub = I have a 12'' dc lvl 4amp = AQ1200d
L x H x D
28'' x 18'' x 14''
28'' x 16.5'' x 3''
LOL ok I wasnt serious, it would take him and 50 friends to do mine neverthless this mess... sorry kid. When you said wasnt to scale it made me think of Back to the Future Doc!
kingtube69
kingtube69
Sydney, Australia
hatedonmostly
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
