ignition wire
or you could just get ACC from the orange wire on the ignition harness or if you need a true ignition use the pink wire
please explain to me true ignition. if it is switched power obviously it is on ign 1 or 2 no matter where you pull it from.
your ignition harness has a pink wire that is true ignition (12v when the key is in the run position)
the orange wire is ACC (12v when the key is in the accesory position in gm cars remaining active until the drivers door is open with the key out)
what exactly are you trying to do?
im wondering whats a true ignition becuz i thought any power that went thru the car when the key is turned would be ignition.. but to save time could u tell me what shall i do to wire it 2 fuse box
datsmeant20
datsmeant20
jacksonville, fl
datsmeant20
