djvi0lent
I'm installing a new cd player in my '05 Century, and it will not power on unless the red(ignition 12v) is connected to the yellow(constant 12v). If the ignition 12v is hooked up properly, the head unit will not power on at all. I've checked the ignition 12v wire with a meter, and it is not receiving voltage when the ignition is on. I've checked my fuse box, and nothing is blown. What could be my problem, and what do you guys suggest? By the way, I'm using a schoshe wiring adapter.. and I've tested another cd player in this setup, and received same results.
