If you had to pick one of these 2 amps what would it be?
porksoda
Well I am on the search for a amp to power a RE SRi-D2(RMS: 300 watts) and after searching I have come to the decision between these 2 amplifiers. They are actually pretty fairly priced for my daily driver build. That is about my budget for an amplifier right now ($60 or so).
I think either one will be good for my budget build.
Option 1:
Crunch P1 600.2 Power One 600W Max 2-Channel Car Amplifier/Amp
* Power One Series 2-Channel Class A/B Car Amplifier* RMS Power Rating:
o 4 ohms: 75 watts x 2 chan.
o 2 ohms: 150 watts x 2 chan.
o Bridged, 4 ohms: 300 watts x 1 chan.
* SEPP Class A/B analog amplifier
* Pulse Width Modulated MOSFET power supply
* LED power (green) and protect (red) indicators
* Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
* Slow un-mute soft start turn-on
* 2/1 channel operation
* Speaker-level inputs with signal sensing for automatic turn-on
* Preamp RCA outputs to daisy chain multiple amps
* 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
* Heavy duty aluminum alloy heatsink for extreme heat dissipation
* Nickel-plated RCA level inputs
* Nickel-plated screw terminals
* Input sensitivity:
o Level: 200mV-6V
* Variable high-pass filter (60-12,000 Hz, 12 dB/octave)
* Variable low-pass filter (30-250 Hz, 12 dB/octave)
* Damping factor: >180
* Frequency response: 10-45,000 Hz
* Dimensions: 7-7/8"L x 9-7/8"W x 2-1/16"H
* 8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* Authorized Internet Dealer
* 1-year Manufacturer's warranty
Option 2:
Autotek MM125.2-RB (LS-mm1252-RB) - Sonic Electronix
* Autotek Mean Machine Series 2-Channel Class A/B Car Amplifier* RMS Power Rating:
o 4 ohms: 125 watts x 2 chan.
o 2 ohms: 160 watts x 2 chan.
o Bridged, 4 ohms: 320 watts x 1 chan.
* MOSFET power supply
* LED power indicators (green/power, red/protect)
* Bass Thrust - Variable Bass Equalization (0-18 dB @ 45 Hz)
* TCID (Twin Coil Isolation Design)
* 2-Channel operation
* 4-way protection (DC, short, thermal, overload)
* Aluminum autoTek illuminated shroud
* ASPS (Auto-Step Power Supply)
* Chrome-plated RCA level inputs
* Chrome-plated screw terminals
* Variable High-Pass (10-1200 Hz)
* Variable Low-Pass (50-150 Hz @ 24 dB)
* Subsonic Filter (10-1200 Hz @ 24 dB/octave)
* Frequency Response: 10-30,000 Hz
* Dimensions: 10-1/2"L x 10-1/4"W x 2-1/2"H
* 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* 90-Day Manufacturer's warranty
* Item Condition: Factory Refurbished
The Autotek, only because ive used their smaller 2 channel like that model before with good results. Is either amp stellar?...no but between the two i say Autotek.
I called Sonic Electronix and they kept telling me to get something else besides either of these amps.
They said both are overrated on the RMS scale and I had to find a amp that was CEA Compliant.
Also they said that the Crunch amp goes into Protect mode for no reason alot, but the rep had no answer why
it would go into protect mode. He just kept trying to get me to buy higher dollar amps and CEA Compliant amps.
Are they trying to just up sell me to something else?
I called Sonic Electronix and they kept telling me to get something else besides either of these amps. They said both are overrated on the RMS scale and I had to find a amp that was CEA Compliant.
That my friend, is how salesmen make money
they are made by the same company and they both are kinda ghey. but autotek is supposed to be a little better built than crunch but who knows? i say the autotek because nothing crunch produced ever impressed me , including the few zed made crunches
they are made by the same company and they both are kinda ghey. but autotek is supposed to be a little better built than crunch but who knows? i say the autotek because nothing crunch produced ever impressed me ' date=' [b']including the few zed made crunches[/b]
My 150w rated ZED Crunch puts out 330w @ 4ohm, if that doesn't impress you then you have a vagina. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Buy my NINe.2x it does 600 at 4 ohm with 12.5 volts.
porksoda
porksoda
USA
Ignatowski
