SoundStream Amp
* Number of Channels: 2
* RMS @ 4 Ohms: 350 watts x 2 chan.
* RMS @ 2 Ohms: 700 watts x 2 chan.
* RMS Bridged @ 4 Ohms: 1400 watts x 1 chan.
* T.H.D.:
* Frequency Response: 10 Hz - 50 kHz
* S/N Ratio: >115dB
* Damping Factor: >500
* Input Sensitivity: 0.15 - 12.0 V
* Crossover Slope: 12dB
* Crossover Frequency: 50 Hz - 5 kHz
* Dimensions: 10.75" x 2.6" x 24.25"
* Variable high pass, band pass, low pass
* Variable 18dB bass boost
* Double sided glass epoxy SMT circuit board
* PWM mosfet power supply
* Tri-guard amplifier protection
* SMT cooling fan built in
* Tri-mode capable
* Line output
* 1-year SonicElectronix.com warranty
Amplifier Specifications
Number of Channels 2
RMS Power (4 ohms) 350 watts x 2 channels
RMS Power (2 ohms) 700 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 1400 watts x 1 channel
Total RMS Power Output 1400 watts
Peak Power Output N/A
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power
Speaker Level Inputs N/A
Preamp Outputs Yes
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 45 - 6800 Hz
Low-Pass Crossover Frequency 45 - 4600 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio >115 dB
Channel Separation Yes
Bass Boost 0 - 18 dB
Bass/Gain Remote No
Fan Cooled Yes
Fuse Rating 40A x 1
Warranty and Return Policy
I dont think so. It says it is not stable at 1 ohm, which means it would get hot fast. I would guess that it is 70% accurate.
If you bridge it, 2 ohms would be about as low as I would run it.
I also see it has two fuses on the body, but this site listed only one 40 amp fuse.
http://www.sonicelectronix.com/item_5404_Soundstream+TRA1400.2.html
Preamp Outputs Yes
High-pass (HP)
Subsonic Filter N/A
Bass/Gain Remote No
Fan Cooled Yes
Fuse Rating 40A x 1
Bass Infection
Bass Infection
Wisconsin
Bass Infection
