If my box is tuned to 42 can I set my ssf to 32?
Type of Enclosure: Vented
Enclosure Sub Size: Dual 10"
Dimensions in Inches: 14.25" L x 32" W x 12 H"
Top and Bottom Depth: 14.25"
Mounting Depth: up to 15" (enough depth for any sub on the market)
Port Dimensions: 2" x 18.5" x 10.5"
Gross Volume Per Sub (Measurement for the outer dimensions of the box): 1.61 Cubic Feet. (2) Rockford Fosgate P3D4-10. I'm planning on running the amp at 1 ohm. Amp is MB Quart DA1-1800.1 RMS Power @ 4 ohms250 watts x 1 channels
RMS Power @ 2 ohms500 watts x 1 channels
RMS Power @ 1 ohm1000 watts x 1 channels , my set up is being delivered but don't want to blow it as soon as I get it
That would be a decent starting point. Go easy on things as you feel out the limitations and keep an eye on the excursion as you play various music.
this
really depends on your power and how well your enclosure loads OP. start there and if you hear no bottoming even on low songs just slowly lower it but i would never go below 25 and that is REALLY pushing it unless you have very little power going to the sub.
GtzStunna
GtzStunna
Canada
LosIsATool
