ideas?
I got a friend bugging the crap out of me about his d@mn w7's. I got 1.5 stuck in my brain //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif . The reading should be in the ballpark of the nominal ratings on the coils. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can't be sure that you will actually get 800w out of the amp. your 2ohm load won't be a 2ohm load normally once you put the subs in the enclosure, due to impedance rise. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
true, but to set his gains with a dmm, do you have to assume everything will stay constant?
well i never knew that impedance rise made such a large difference in resistance. and theoretically itll do 1200w at 2 ohm, but thats way to high, so i decided on 800 (which is prolly what'd do at 2 ohm anyways)
I've been an electronics tech for 5 years and have never heard of impedance rise.
The concept that the fact that the sub is in an enclosure has no bearing on the electrical resistance of a coil.
I've been an electronics tech for 5 years and have never heard of impedance rise.The concept that the fact that the sub is in an enclosure has no bearing on the electrical resistance of a coil.
hook a DMM up to your subs coils, and press the cone up and down. The impedance will change, as it does with frequency. Usually never drops below your speakers Re.
the subs coils check out. so it isnt that. i tried wiring them different ways and still got nothing. but what i did find is that without the sub hooked up, the amp puts out V at the terminals, but when the sub is hooked up, it reads nuthing on the DMM. which leads me to believe the amp is bad. am i correct in assuming this? oh and i also tried new RCAs to be safe
fatryan
Banned
fatryan
Southampton, Pa
fatryan
