ideas?
fatryan
Banned
just installed my boys system (P3 and PA 600w 2 channel). i got 2 problems. first, when i tried to set the gains i couldnt get the desired voltage. the amp puts out 600 at 4ohm, but im using a 2 ohm load. i tried setting the gains for 800w (sqrt(800*2)=40), but with the gain all the way up, it only reads 18v. theres no setting for high/low level preamp v either. the deck is a deh-p3700 mp3.
second problem, the sub doesnt play anything. the amp reads 18v at the speaker terminals, but the sub doesnt flinch. its a DVC4 wired in series. i dont get it. i contacted forsgate forever about it cause he sold it to me, but havent heard back yet. you guys got any ideas?
Did you check the sub's coils with the dmm to make sure they weren't fried ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
See the sub's terminals?
Stick the red wire on the positive one and the black one on the negative.
And I know the term, the sarcasm hidden in my post was that I think it makes you look silly by saying it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Just IMO, though.
how do i do that? i think my DMM atuomatically detects DC or AC
Stick the leads off the dmm, onto the sub terminal or the wire connected to em //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. All settings on the deck correct?
Does the deck have a sub control?
Is the amp stable at 2 ohms mono? Why is the gain set for 800 on a 600 watt amp?
you mean how you said set it to DC? thats gay.
anyways, ill try it when i get home saturday. what reading should i look for? the resistance of each coil?
Stick the leads off the dmm, onto the sub terminal or the wire connected to em //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. All settings on the deck correct? Does the deck have a sub control?
the deck is a 3700. it has front and rear preouts no sub, but ive used rear b4 for the sub nd its worked. and also, the amp is reading 18V at the terminals, so it must be working.
the amp ISNT stable at 2 ohms mono, but ive been told by some people that itll handle it fine. and the amp doesnt jump into protection mode or shut off or anything. it works fine, just the sub plays nuthing. i was setting the gain for 800 cause "theoretically" at 2 ohm mono, the amp would put out 1200w. and i know tghe amp is overated + i dont wanna fry the 500w rms sub, so i set the gains for 800w.
anyways, ill try it when i get home Saturday. what reading should i look for? the resistance of each coil?
Set the dmm to the horse shoe looking Symbol for resistance. Then red to the positive, black to negative. Should be in the ball park of 1.5 for each coil. Give or take a little. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
isnt that the sub that HE didnt even know the vc config on. By HE i mean Fosgate Forever? Cause if thats the case, i bet your subs f'ed up.
yeah, but im not gonna make any assumptions because he seems like a real nice guy. so im gonna give him the benefit of the doubt. i just would like to know what all i need to do to troubleshoot the problem
thats what i would have guessed to do. but tell me why it should read 1.5 a coil? i would have thought it would be 4 a coil
fatryan
Banned
fatryan
Southampton, Pa
fatryan
