ideas on an amp rack?
I just did something similar to what you're describing. Might not be perfect for your application, but itll give you an idea. I made it simply by putting 2 triangle legs onto a flat face.
3/4 MDF. Measures 2" bigger on each side than my amp. I used the Pythagorean theorum to get the length of the cut i'd need because i approx. the height i wanted and measured the depth + height.
I covered it in vynal from the local Joan Fabrics. I then used 1/4" spacers from home depot to raise the amp off the rack for cooling purposes
Yeah true well he welds all the time so he's got the metal plus i think it would heat the metal up to much even if it did have the spacers what u think?
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
