ID12v3....they wired the sub wrong?
Ive seen professional subwoofer makers use 9V batteries so id say its plenty safe.Please dont argue.
Sure you have....You also said 4 posts earlier that you knew 1.5V wouldnt work...I am actually looking for a new set of subs, let me know who these professional sub builders are so I know which ones to avoid.
Bill Nye 101
a 9 volt battery will not hurt a sub unless it has a thermal rating of well under 100 watts.
9 volts into 4 ohms is 20.25 watts.
9 volts into 2 ohms is 40.5 watts
1.5 volt into 4 ohms is 0.56 watts
1.5 bolt into 2 ohm is 1.25 watts
I have alse seen some very smart people say a 9volt is fine on any speaker. Also you only touch it for a second so ther eis no more stress then a note being played.
Bill Nye 101
ok might wanna avoid tc sounds then //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I'm not going to disagree, I was just trying to make a point that 1.5 is probably safer. The other guy was trying to take credit because he knew that a AA would not work when in fact it works fine.
.56 watts (1.5v) is plenty enough to make a speaker jump for polarity checks. That was the point which I was trying to make.
i never said it woudlnt move it.
I was more posting it since you said you would avoid a company that uses a 9volt battery //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It is easier to see on bigger low sensitviity drivers with a 9volt. I use both //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No biggie...It is my OPINION that I feel it is safer to use 1.5 volt than 9v. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It is a FACT that 1.5v can be used to check polarity.
you guys must be bored to claim that a 9v battery could ever hurt a speaker when testing for polarity. You can put one on your tounge and does it make your speaker coil smoke???
Using a 9V battery will show the cone actually moving. Which makes it much eaiser to check vs a AA battery.
Just because im right doesnt mean you have to argue
M@nJo
M@nJo
bay area
Cubed1
