id oem users???
davidt487
David
i bought a set of these and with less than 75 watts on them the are popping. crossed at 80 24 db slope. doors are deadened but not sealed but the mid is competly though the door like a ib install. what is causing them to pop im reading about everyone putting 200 watts on them and i cant get away with 75.
thanks for the imput
I cross mine at 63HZ, w/ 24db/oct. crossover ran off of an SAX 100.4 and I dont have any issues //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif My mids barely move.
what amp are you useing?
you may try changing your db slope to find the right xover point for your set up.
you should finish deadening your door.
make sure you have a completely tight seal around the mounting ring.
The falls Huh? we need to have a texoma meet....
yes we should
the reason i didnt seal off my doors is because there are rods comng through the hole and i dont have a clue what could use to bend into the shape. the hole is on uneven surfaces.(if that makes any since)
davidt487
David
davidt487
wichita falls, TX
okiedokie
vegang
vegang
