id much rather draw it...
Do it like this, its really simple-
that is exactly how you should do it. But you can switch the wire that goes from the negative of the amp to the negatives of the voice coils from one terminal to the other. If that is what you are asking. LIke instead of running the negative wire to the bottom terminal you can put it on the top terminal just like the positive is on the top terminals.
vasilios
vasilios
Chandler, Arizona
monte_carlo97
