id much rather draw it...
vasilios
ive a dual 2 ohm sub. when wiring for one ohm; pos-pos, neg-neg on sub then neg out and pos out to amp, does one out need to come off the pos of one voice-coil and the other out come off the neg of the other voice coil or can they come off the pos and neg of just one voice coil? make sence?? thanks.
No. you can wire the postive and negative from the amp to each terminal on 1 voice coil then have another two peices of wire to wire from that terminal next terminal. Both need to be wired.
this is why id much rather draw it...that is what i was trying to say; p-p and n-n on the sub then on one voice coil, n-out and p-out..
Yes! Haha. crazy confusion there for a second. Thats the point of the wires on the subs is so you don't have to amp both sets terminals if u get what i'm saying
yes i know this...my question is can i run the outs from the pos and neg of one terminal instead of running them from both terminals???
yes, the pictured showed this //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
vasilios
vasilios
Chandler, Arizona
monte_carlo97
