Id like some advice as to what to do next.
So my overall goal is to simply have a freaking amazing Camry. Its fun to have people get in and blow their mind with sound quality and clean bass.
Headunit= excelon x598. Simply works. Source is wired newer ipod.
Currently i have the Hertz Esk 165.5. Ive got the tweeters mounted on sail panels and everything is running active with a sundown 150.4
Subwoofer is an sa-12 with a cerwin vega 1000.1 in a 2.2 cuft box tuned to 32 hz.
Sound deadened the doors, Did big 3.
My overall goal is Hertz HSK 3 ways. Jbl ms8 and too wall off the back trunk and put a Xcon in it, tuned to spec, with a Soundqubed 2200.
I know thats double the power im going to need, i like the sa-12. Its not the best for sound quality but its decent so i can hold off on that. Thats ok with me.
So im kind of wondering, Should i sound deaden the rest of the car first or get a better battery and then alternator. That alone is in the 5-700 mark. Im just a young 20 something kid trying to spend his money wisest. if i need to step up the electrical, I shall but if i dont, then i wont.
Whats your all of your advice as to what would be the next best step?
130 amp alt with the camry and the electrical system is pretty efficient without a lot of draws from the vehicle. just a good agm under the hood and big 3 upgrade is all youll need to stay above 13.2 volts as long as you are not heavily clipping. Invest in a lot of foam for rattle treatment and a good box. You dont need a high output alt for just 2 to 2.5k with toyotas.
The Camry
Hey, I Try.
The Camry
Western Oregon
The Camry
