Wow your an idiot keep posting to keep this thread entertaining please.sure james....come to florida and we'll see how much you think you know. any numbers from you yet? TL sealed on dash?
That is mids and horns I think.Ouch, Ill stick to my CTX65cs, and OEM's.
FAILEDhmm...that FL...statement makes so much sense...NOT!
i'm not one of those fl boys who put speakers on the outside of my car...all my speakers are designed for inside and will stay inside....no need for everyone to hear distorted harsh vocals.
there's some truck/horn install around... i'll post if I find them.Anyone run them in a truck? The way you sit it seems like it would block the sound.
I don't have a truck.Looks like James Bang's are in a truck.
approx how much are a set of ID horn's? Something i may be interested in, If i could only go active [stupid dual deck.. Blah.]
If it isnt installed, How do you know it sounds clean? Im hoping my euipment sounds good, But its 90% install, 10% equipment. Just because you have the best of the best stuffed in your ride, Dont mean its gonna sound the best.
I sold mine for cheap.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifThe entire set is like $650 new I think.
I dunno, he seats are far back. I can't really move mine that far back.
i have a set of the Ultras that Ill be putting in an 05 dodge ram. Not sure what youe mean by the way you sit would block the paths. After I hack some things up I should be able to fit mini bodies. ahould be starting a build log in the next cpl weeks.Anyone run them in a truck? The way you sit it seems like it would block the sound.
Keep in mind the horn uses the dash as sort of an extension of the horn itself, which is part of the reason why you can still get a nice high stage with something aimed at your shins. It's also the reason coupling the horn mouth to the dash can be important.Anyone run them in a truck? The way you sit it seems like it would block the sound.
do you plan to send a ton of power to them and beat on them? if so from what i have heard the xs comps are more forgiving.That is mids and horns I think.
I am looking at the XS or CSX...dunno which
And for that I will always love you //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gifI sold mine for cheap.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
indeed.Keep in mind the horn uses the dash as sort of an extension of the horn itself, which is why you can still get a nice high stage with something aimed at your shins. It's also the reason coupling the horn mouth to the dash can be important.
you were the only with brains quick enough to jump on them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifAnd for that I will always love you //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I was thinking because they'd be firing so low.i have a set of the Ultras that Ill be putting in an 05 dodge ram. Not sure what youe mean by the way you sit would block the paths. After I hack some things up I should be able to fit mini bodies. ahould be starting a build log in the next cpl weeks.
I believe you, I do. But it's hard for me to believe without seeing. I may call Eric from ID to see exactly how to do it.Keep in mind the horn uses the dash as sort of an extension of the horn itself, which is part of the reason why you can still get a nice high stage with something aimed at your shins. It's also the reason coupling the horn mouth to the dash can be important.
Not a ton...I haven't even started deadening yet. I am just thinking.do you plan to send a ton of power to them and beat on them? if so from what i have heard the xs comps are more forgiving.
i own the xs comps and love them.
i cant give too much info on the csx line though. i have a pair of id oems and thats basically a csx mid but i havent heard it yet //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
