Sold ID CX64 Mid / Eclipse Alum Sub & HU for sale...
specs on the eclipse?
Eclipse 55040
# ECLIPSE COMMANDER Ready
# Equalizer/DSP Sound Processor Control
# CD Changer Control with Daisy Chain
# CD Text-Ready
# High-Voltage (8V) & Low-Impedance (55 ohm) Output:yumyum:
# 3 Pairs of RCA Pre-Amp Outputs
# Whole/Partial/None Display Selector
# Independent Bass/Mid/Treble Memory for Each Source
# Non-Fading RCA Pre-Out Terminals for Subwoofer
# High-Visibility VF Display
# Tilting Front Panel
# ECLIPSE LAN Advanced Data Link System
If you want the eclipse commander, dsp, or cd changer you have to buy them seperately but it will control them.
Eclipse 88100 Alum Sub
DC-R 3.1ohms per coil
Fs 26Hz
Qts 0.47
Vas 2.10ft squared
spl/w/m 84.9
Qes .513
Qms 5.6
Xmax 3"
Handles 500Watts RMS with ease...1.25 cu ft. recommended
I used it in a 1.25 cu ft box with 380 watts RMS, and it hit nice and clean. It's a very good SQ sub, very musical and easily integrates with the front stage.
Thanks.
my bad, I forgot to specify that I was talking about the sub. $75 shipped? isn't that a pretty low price for that sub? regardless, I'm interested but I need to see how much I have in checking.
question for anybody that could help, if my amp is only 2 and 4 ohm stable which way would be better to wire it? (I have an mtx thunder 7402)
That sub can only be wired at 1.5 ohm or 6 ohm. Neither is a good match for your amp. You might get away with 1.5 ohm, but you'd be pushing the amp very hard. And at 6 ohm you're not using much of your amps potential (you'd be getting in the neighborhood of 200w from it). You should buy a dual 2 or dual 4 ohm sub.
runmeshaw
runmeshaw
Bay Area, CA
runmeshaw
