IA Death Penalty wall socket Video
yeah there's plenty of them, a friend of mine had his MT"s on a wall socket overnight to help them wear in.
ahahahah, thats going in my sig!
why do people have to flat out lie like that? to make themselves feel better or what? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I think you lost your privileges to make fun of people when you said this:
hmmm, thats interesting, care to explain why? also, if you car was loudest at 50hz, couldnt you just buy like a 2000 watt power inverter and use it for burps instead of an amp to save a lot of money?
If you want to run the inverter to full potential you have to wire it to a load that will allow the inverter to run 2000w@120v.
FYI it is 60Hz for many reasons. We use AC because AC current travvles further with less voltage drop, Alternators are lower maintance than generators (and alternators creat AC current), 60Hz is nice and low so inductance doesnt cause a problem in voltage drop over long distances, and 60Hz means the alternator only has to turn at 60 times per second.
shut up, thank god you have a lifetime ban at Soundillusions //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
hopefully here too //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
actually, a wall socket can work quite well for break-in. just use a dimmer knob //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i was about to quetion you until i saw your sig, is this how you did yours????
i did this on the atomic i'm using right now. thing was stiff as hell when i reconed and needed it alittle looser by the morning. also, wired the coils in series for 1.4 load.
using a low frequency and low power actually works the best, however, i didn't have that available to me in my kitchen //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
skadude016
skadude016
Canton, GA
delvryboy
