IA Death Penalty wall socket Video
Didn't seem to last very long. :shrug:
It's a dual .7ohm coil (actually, a quad 1.4 ohm coil with coils offset 90degrees and paralleled)...
One coil had a break in it, totally gone... another coil was about to go. So... it was already ****ed...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BTW, I know this b/c it used to be my buddy dave's sub... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif... and I had helped recone it before...
nG
nG
Yeah, i didn't know the sub was that messed up until the thread starter posted that later. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So from that info i guess it lasted long enough. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
depends on the electricity in your country... either 50 or 60hz
hmmm, thats interesting, care to explain why? also, if you car was loudest at 50hz, couldnt you just buy like a 2000 watt power inverter and use it for burps instead of an amp to save a lot of money?
Because wall socket electiricty is AC, and, for whatever reasons, the guys that decide this stuff made 50 and 60hz the speed at which it cycles.
The inverter thing could work.. the only problem is that most inverters are incredibly overated. An inverter that could create 2000w would require an IMPRESSIVE step-up transformer (read as: expensive). Something like this is a starting point...
edit: oh yeah, i forgot, inverters that create that much power can actually be more expensive than car audio amps (which are far more useful for creating a range of sounds... an inverter is kind of limited.)
check froogle to see what i mean:
http://froogle.google.com/froogle?q=2000VA+inverter+price&hl=en&lr=&safe=off&sa=X&oi=froogle&ct=title
still want it? jus needs a recone //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It needed a recone before i did this. coils were rubbing and only 3 of the 4 coils worked
how much for the motor?
/edit
oops old thread/
skadude016
skadude016
Canton, GA
delvryboy
Mike Mccabe
