I am in a tough spot. Looking for something that will do 3500 watts at the min, more around 4k would be just perfect to give 2k per 12" sub. MY budget is 800 bucks tops would like to stay in the 600-700 dollar range. I am needing something that is efficient. My electrical will only be either a 150amps at idle and 250 max mechman, or dc power 175-200 at idle and 300 max i think. With big 3 done, gold duralast upfront (plan to upgrade to hc1400 or 2000). Stinger spv70 in the back run of 1/0 ground and power to the back ( will make that 2 runs of power and add 2 runs for grounds as well since they say not good to ground to frame best to run to front battery.) If needed will put another spv70 in the back or two. ( or batcap 2k w/e is the best battery for my daily setup and best bang for your buck.
Need something that is efficient and will do really good power, want to keep my voltage at 12.5-13 to get alot of power out of the amps, this is for daily no competition.
so what would you say??
How do the IA 40.1, sundown 3500, and rd 5750.1 compare, hell even throw in the AB 400.1, along with stetsom 4k2?? dont want a memphis 4k current hogs i hear
