I would love this headunit
>>SQL<<
USA
Has to be the pimpest HU I have ever seen.
PANASONIC CQ-TX5500D VACUUM TUBE CAR CD MP3 DSP STEREO | eBay
rreally? you have a 73 gremlin to match? not to mention I dont find the distortion tubes add to the sound to be pleasant.. to each their own i spose
No 73 Gremlin sadly //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I just think how un-new-tech-like it is seems sexxy to me.
I have a Mac //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That Panny bottlehead is sexy as fawk. The tubes are on the amp output though, so unless you want to run your front stage off HU power, they're just for decoration. There is another model that's similar in looks but without the tubes. I want that one. I forget the model number but it's all stainless and has the analog meters.
417
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
997
>>SQL<<
>>SQL<<
USA
TaylorFade
    May 18, 2024
    May 18, 2024
