I want to use a passive crossover on my mid's ... question
tylerj
NE
Im running active.
Tweets are highpassed on an active crossover.
Mids are highpassed on an active crossover.
The active crossover lacks a lowpass crossover to put on the mids.
I have a pair old eclipse sc8254 passive crossovers. Can I run the 2 mids on each side, each on a passive crossover, without changing the impedance of the load?
4 ohm mid +parallel+ 4 ohm mid ---> passive crossover ---> amplifier
Will the amp still see a 2ohm load?
I'm not a passive crossover expert, but those crossovers are most likely designed for 4 ohm woofers. Two 4 ohm woofers in parallel will present a 2 ohm load, while at rest, to the crossover. It will not give you the same low pass filter characteristics as if you connected one 4 ohm woofer.
tylerj
tylerj
NE
trumpet
