I Want 4 Or More 15" Or 18" Subs In The Bed Of My Truck
A guy over at ICIX was able to seal two eD 19.Ov2s behind the seats of a regular cab Ram. Perhaps you should go that route. You don't seem experienced enough to tackle a blow through with 1 18, much less 4. No offense but you have a lot to learn.
well i am pretty experienced with car audio i just never really had the money to put the amount of subwoofers i wanted in my truck!! as for subs behind the seat that would never work because i am 6'4 365lbs and i need all the room i can get!
i have inside the cab right now 10 kicker 6x9s which will soon be in the doors in a custom fiberglass setup
EEk!
Seeing as how he doesn't care about SQ, I wouldn't go with the 2 rlp's. 4 mj-18's will require the same amount of power, it will look more impressive, and yield higher numbers. Throw the same 2000 watts on all 4 of the mj-18's.
the rlps have much more potential than the mach5... 2 of them can hit high 140's if done rite... take less space, its only more expensive... you get what you pay for...
im not worried about space. my goal is to make an install to cover the entire bed of my truck.
GO BIG OR GO HOME
tank56ht
tank56ht
Hearne, TEXAS
jlaudio38
