I Want 4 Or More 15" Or 18" Subs In The Bed Of My Truck
No way in hell you can do that on a $1200 budget. You'd still have to get amps, batteries, wiring, and bigger alternator.
well i have a 250 amp alternator and my current starting battery is a dry cell. what do you suggest i do? im trying to build a killer setup for the bed and tunnel the sound to the cab. this will be my biggest install yet so any help is much appreciated
i say you get 2 rlp 18" with a minimum 2000rms amplifier.
quality > quantity
Seeing as how he doesn't care about SQ, I wouldn't go with the 2 rlp's. 4 mj-18's will require the same amount of power, it will look more impressive, and yield higher numbers. Throw the same 2000 watts on all 4 of the mj-18's.
ok i have decided that if i get the mj-18s im going to get 5 of them two on both sides of bed and 1 at the rear! i am just wondering how good these subwoofers are? and what kind of numbers do you think i would throw out with this setup
are you talking about just the materials for the setup or including the subwoofers and amps?
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif You are no where near being able to get that on your budget. He's pulling your leg.
4 15's or 18s and amp off 1200 probably aint going to happen if you want QUALITY stuff...especially if your wanting BNIB. Ive put well over 1500 into just my 2 15's and 1500 watt amp just to get everything i need to make it right...
you gotta figure in batterys, wires, connectors, box...everything.
5 mj18s shipped will run you atleast close to $600-700 maybe more since 4 18s would be big and heavy. That will only leave you 500 amp AND for box, wires, terminals, batterys, etc. You will probably spend ATLEAST 350 on good box mats, good wiring and a good battery (youll prob need 2 for this actually) That will only leave you with about 150. You will be very hard pressed to power 5 18's off a $150 amp...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Edit: 5 on BOTH sides and 1 in the rear? Thats 11 18's man......you need to like....take your budget and multiply it by 10...or more.
I run 4 MJs in a daily setup and they did a 148.4 sealed on the dash. They are also only 105 each shipped. They also only weight around 25 lbs each. All ready stated has a 250 alt and dry cell. Prob need one more.
4 MJs 420
Hk4000 in classifieds 375
Kicker 1/0 kit 100
Everstart deep cycle 100 from WalMart.
Doesnt look to bad
tank56ht
tank56ht
Hearne, TEXAS
jlaudio38
