jeremyblevins
Okay so the other day my car wouldn't start i'm like wth. so i checked my voltmeter and was getting around 11 volts so i guess my battery is dead. so i get a jump start and my voltage just up to 12.4 ish so i drive my car for a bit like 3 minutes turn it off then it starts again so i drive again for like 15 minutes turn it off and turn it on then is starts and drive alright but the voltage always seems low. so i let it sit over night and it wouldn't start and will only start when being boosted now. i checked the battery at advance and they said it was fine just low on juice. but i disconnected the battery while the car was running but the car didn't stop?
So i'm thinking the regulator in the alt is busted?
i was watching just now while it was running and the voltage would sit at 12.4ish but kick up to 12.9 when the a/c kicked on.
any suggestions?
and if my alt is busted would a 200 amp one be good? Or should i be able to get by with stock?
my system is the mustang stock mach 460 sound system with 2 10 inch type r's hooked up to an audiopipe 1500d at 2 ohms giving me around 950 rms.
is this a good place?? DB Electrical - Ford Mustang 200 Amp High Output Alternator 4.6L 96 97 98 7776
sorry for the long winded post but i'm leaving for work and wanted to get all my questions out
thanks in advanced for the advice.
any suggestions?
