I'm planning on running a dual battery set-up (one under hood and other in trunk). I had a Rockford Fosgate dual amplifier wiring kit that came with 1/0 power wire and I bought 1/0 welding cable recently to run ground from battery under hood to battery in the trunk. Simple question; will 1/0 ga welding cable be okay for ground? Only reason I was questioning is because, the RF wire looks a little larger and read somewhere that the ground wire needs to be equal or larger than power wire... Thanks in advance.
