Pl8er
Can you solve it?
Ok, I have 2 ED 11Ov.2's running on a Nine.1 in a (I know this is going to get me beat up) ported to I believe 34hz prefabbed box. I am running a RF symmetry and I have the crossover set to 80hz on my lowpass, my bandpass (just what it is called on the screen for midrange) starts at 80hz and I have it cutoff at 1.5 (acendant audio high excursion poly 6.5's) which then goes to my front stage (CDT 61-A) that are running passive so I have them on full pass.
Front end sounds good enough (because I didn't have to do much) and the rear fill sounds ok, but my subs just don't hit much. Should I set the crossovers differently than I have them? I am using no bass boost on the amp, gains are off as I use the symmetry.
Anything I could do that could change this? I know I need another box but I'm having a hard time finding someone to build me one that could integrate the amp rack into it ( I want the back of the box to slope down and have the amps installed there with my symmetry, and dist. block.
Sorry for the long post. If anyone is in the columbus, ohio area that can build good boxes, let me know as well.
Thanks!
Thanks!
