i should i use a bigger fuse
The fuse is there to protect internal components. If you just add a bigger fuse, you'll likely wreck your amp. It wasn't meant to put out that kind of current.
When you wire lower, there is less resistance and your amp puts out more power. Voltage doesn't change, amperage does. More current is allowed to flow. Think about how small some internal components of your amp are..
Also, if you fuse larger than your wire is rated, that defeats the purpose..
The CT's are nice, That Sundown is a a frik'n beast!
766
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
655
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
753
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
sharkman
poor bass head
sharkman
oakland ca
adulbrich
    May 20, 2024
    May 20, 2024
