I seriously need some help
oh gee... I so want this done. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm set on the L15. Done, I want very clear mids and omph in midbass. Done.
I'm thinking the Seas 27TFFNC/G (H1396) will fit in the apillars, if not the midrange location.
Thought about adding that Aurasound NT1-204-8D as a super tweeter above 12000 in the apillar and the 27tff in the midrange. Is that the right thing to do and go passive inline on that one driver? Or is that more trouble than it's worth?
cross over 80hz sub.
The more I research, the more I'm thinking the AC130 might actually be the best driver for this situation. It's looking like the MK2 has a slightly higher breakup than the F1, but it's not very high, and makes the driver very usable up into the 3k range (which would meet up with the LPGs just fine). The F1 does have the distortion at 1.8k, but most likely inaudible in a daily driving situation. Vehicle off, eyes closed, and just the right song, on just the right recording might be audible, but if you listen to music like that, get a home audio setup.
I don't know what the difference between the F1 and the MK2 would be tonally. I don't know if it's the cone material that causes the distortion at 1.8k or the motor. If it's the motor, then the MK2 will probably yield less distortion. It's probably the case either way, and if it's a concern might be worth the extra few dollars.
Either way, I think it might be a good setup. I can't be positive because frankly I've never heard it. However, Zaph's T/S parameters are making me a believer. All other things being equal in his testing process (which can't be said between manufacturers), the AC130 has a lower Fs, and a higher Qts. That tells me it will react better in the door than either of the Seas options. How much better? It might be minute, or not at all. Numbers are numbers, and don't tell the whole story. The distortion at 1.8k will be inaudible with either the F1, or the MK2, in a moving, or even idling vehicle, no matter what's being played.
And the best part... it will match up to the LPG tweet. For the most part, it looks like it should be a great compromise between the Seas drivers.
If I was in the market for a 5 1/4" setup, then I'd sure give them a try. Of course, that means very little when it's your money, and not mine. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Either way, I say give them a try.
After many, many days, I'll finally stop waffling and say AC130/LPG combo FTW.
****IT, ****IT, ****IT, ****IT!!!!!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
After just touting the AC130, back to the original plan.
If you can get the Seas Neo in the a-pillar, then by all means go for it. That's still the best option. If you want to use both, regardless, then yes, the Aura tweet could help if you are willing to do the extra work. You'd most likely want to run them off head unit power, and run a capacitor in series with them, throw in an L-pad to be safe, and you should be okay.
Cap value will be tough to say. I'm thinking somewhere between 10 and 13k for the crossover point. 13k will probably exhibit a bit more neutrality, and 10k will probably be very forward. So, with that I'd probably say 12-13k. As it so happens Parts Express has the perfect cap.
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=027-412
Creating a 6 db slope, it should yield just enough top end sparkle. If the Seas Neos are EXTREMELY off axis, then lower the crossover point, and use a 1.8 uF cap.
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=027-914&DID=7
Throw this little do-hickey in there to properly adjust the volume of the tweet, and you should be good.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-251
Of course, this can all be done after you do your initial install and see if it's even needed.
Want to guess how many drivers I have sitting in my garage, and friends garage? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have just as much problem picking a setup for myself, as I'm having with yours so I just accumulate stuff when it goes on sale, just in case, I can find a use for it.
My wife is going to get the Dayton ND20 tweet in her car as part of a 3 way setup. So, I do like the tweeter, even though you're looking at the Aura, which is the same thing almost.
Well hell //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tried to order at Madsion, L15 out of stock.
Then he asked what I was doing. Then he said:
Peerless 850517
Peerless 830512
Vifa A13wg0904
He also said something about the L15 not being so good free air.
On tweets he said the 27ttf without me saying I was looking at it.
Over them all he said Peerless 850517 would be his choice and it fits my door.
His second choice was the Vifa.
Half the Vas, and half the Xmax of any of the other drivers we've looked at.
Frankly, nothing works well free air. That's why we try to seal doors as best as possible. People use egg crate foam behind the speaker to absorb backwaves, and all other sorts of voodoo that either help or don't.
We (as in car audio) look for drivers with high Qts numbers as a sort of baseline for how well the driver will react with large volumes of air, or free air. This doesn't always tell the best story, and can be sort of voodoo as well. The car door does absolutely no favors to any driver. The smaller the driver though, the harder to get decent midbass performance because of the large volume of air. With even a sealed door it is quite large. So, in essence the guy at Madisound is correct. However, suggesting a driver with half the Xmax, and half the Vas doesn't bode well either. It's not a driver that will provide a decent amount of midbass. It may act very controlled within it's usable bandwidth, but there's nothing it can do that the L15 can't do as well. What we're hoping for here is a bit more performance.
The L15 has a higher Qts, and almost double the Xmax, and Vas. You won't get everything the L15 has to offer, but you can get more out of it.
I can throw even more drivers into the equation. Vifa PL14 is a great driver. Detailed, with a very smooth, velvety sound to it. Great upper end extenstion, with good off axis performance. Should provide some decent midbass as well. Low Fs, decent Vas, and Xmax, but lower Qts have made me skip over this driver. Doesn't mean it won't do well, and it could possibly do spectacular, but it's a punt.
Speaking of punting, just about anything will be a punt. There is no way to tell how any driver will react once installed in a car door.
We're trying to work within the parameters of the vehicle without carving out door frames, a-pillars, and any other panels that may get in the way. It's a challenge, and frankly why I'm addicted to this hobby over home audio.
The Seas Neo is a great tweeter. So is the MDT12. The LPG is spectacular at what it does. The Dayton ND20 is a superb little performer for the money. The L15RLY is a great driver. So is the CA15, and the Vifa PL14. I'm willing to bet the AC130 will be nice as well. Peerless makes some great drivers, but nothing I'm willing to stamp for this particular application. If I had to pick a Peerless I'd pick this one.
http://www.madisound.com/cgi-bin/index.cgi?cart_id=3904266.20886&pid=1953
Nothing is going to sound as good in the car as it would in a properly built enclosure for any given driver, including anything "designed" for car audio. So, when the guy at Madisound says the L15 doesn't react well free-air, I hope he's not comparing apples to oranges. He may be correct, but there's a difference between, "this will explode if you try this free air", and "you won't get full potential out of this driver".
I can make an argument for this driver as well.
http://www.madisound.com/cgi-bin/index.cgi?cart_id=8248629.18658&pid=1074
Let's be realistic about what we're trying to accomplish here. We're trying to take a well engineered piece of equipment, and put it in one of the most harsh environments we can dish out, and expect it to perform to a high standard. Same thing as asking a Porsche 911 to do 140 mph on a road riddled with speed bumps and potholes. Something's gotta give.
It's hard to stand back and say this will work and this won't when I know for a fact that unless I'm there with a stockpile of drivers next to you to test, anything will be a punt. I really enjoy spending other people's money, but I have some integrity as to feeling really, really bad if something doesn't work out. So to that end, I try my best to find the best fit for a given application. Madisound is doing the same thing. They have a lot more to lose though if you're an unsatisfied customer. So, I think they're playing it a bit more safe when they make recommendations. Unrealistic expectations can kill a relationship, and Madisound definitely doesn't want to do that.
In the end, it comes down to effort. The more you put into treating the doors, and giving the drivers the most controlled environment possible the better the performance. 80% install, 20% equipment. This is why Dynamat, and Ensolite exist. This is why DIYers like myself go to great lengths trying things like shoving modeling clay all around a baffle, and using egg crate foam behind a speaker, and anything else we may think will help. Some of it's voodoo, some of it actually helps.
Well said. My sense is that when I said car, he went to car speakers without considering other drivers. I have no problem thinking out of the box and working a little harder if I get 20% more gain. I could have gone passive, instead I went active. This is a custom build and not all things that are custom "fit" without modifications or just the easy standards.
My home theater speakers are Fluance. A little known company that makes exception speakers for budget prices. I have no issue spending money based on reviews from people in the know. You can't audition Fluance, it's internet only. I have no problem spending less and getting more.
I would also hate to think I've wasted your time and my time and end up going down to the local earshack audio and throwing some kickers in it. While the man at Madisound was well meaning, my sense was he was not a DYI guy. Not to say that Peerless he suggested bad just that there may be other options.
My other car had Focal Poly 2 way in the kicks. While is sounded pretty good. It was basically decent highs and midrange only. The goal of this build is to exceed that, add at least "some" midbass and raise that front stage. I realize I won't be able to get 80hz in the front stage but anything will be better than what I had.
I do get frustated at times with all this but in the end I think we'll come up with a solution. The Seas will in next week he said and right now those are my leading choices.
Build cost tally will be rather high. $350.00 just to install. I want to make sure my drivers live up to that so it's worth the wait and look at more just to be sure and to hedge my bet. We've come this far, what a few more days to get it right?
Isn't this what we're talking about?
"FYI, I can think of one metal cone that can be used with a first order crossover. If you use the SEAS L15RLY/P and a notch filter around 7.8Khz, you're OK to use a first order crossover. Of course, given the natural rolloff at 2Khz, the effective slope is more than 6db. That seems to bother some folks for some reason. Some of their other metal cones in that series can be treated similarly. "
Jlace
Jlace
Dallas
Jlace
vegang
vegang
