i really need help wiring 2 dual 2 ohm subs to a 2 ohm impendence.
hondaracer48
I have wired these ****ing subs like 3 different ways and it doesn't sound right, I have a sounstream 1000.1D amp that I just bought as well as the 2nd CVR. I had been running the one cvr at 4 ohms for about a year an decided to upgrade to a better amp and additional sub. anyways I currently have them wired like a saw on a website. jumpered the neg and pos with a white dot on them. then the pos and neg without the dot ran to the box terminals. then the box terminals of both subs ran to the amp and tied together both positives and both negs and plugged into amp. and I can hardly head the subs hit at all even with gain all the way up?!
that's exactly how I did it! only thing different is a didn't run the wires from one sub to the other subs coils. I have no idea how to get the wires from one sub into the other chamber of the box without drilling a hole?! also do I jumper the coils with the white dot together or mix match?
they might be dual 4 ohms im confused. subs are CVR102 back of sub says dual voice coils, 2 ohms....does everyone drill a hole to connect the chambers? I bought a pro box so I figured if so it would already have ahole
hondaracer48
hondaracer48
texas
jasonbillnelson
