I really need advice!
Kferling
I own two Kicker comp subs, and they are both discontinued models. One is an older single 12"c 8 ohm Comp housed in a non ported box. The other is the Kicker Comp vr 10" dual 20hm voice coil which will be paired with another in a ported box.
My amp is the Profile California 600MSX.
Specs:
300 watts RMS x 1 at 4 ohms
410 watts x 1 at 2 ohms
MOSFET power supplies
continuously variable low-pass filter, 40-130 Hz at 12 dB/octave
0-12 dB variable bass boost at 45 Hz
I need to know what and why will be my best sub options with what i got, in terms of best punch i guess. The car is a 09 lancer gts.
Thanks in advance! I really need it!
Well you can't run the 12 with the 10 for starters. Second if you can get another one of those 10's with the same 2 ohm impedance than do that. Wire them to 2ohms with that amp and bam you are ready to go. I would just get a prefab sealed for that setup, since a custom box would cost more than both your subs combine.
Kferling
Kferling
Reading pa
ThatChevyGuy
Mike Mccabe
