I need your help! Narrowed down sub choices (I think)
shoeless
28
CT
Guys,
I'm not coming here with a "what's the best sub" thread. I've done a lot of searching and research and have narrowed down my selection. Here are my parameters:
I have an Eclispse ea4000 amp which will run at 350 watts RMS @ 4 ohms (bridged). I want to power a 10" sub in an IB (free air) installation, mounting the sub on the rear deck. If I understand thing correctly, subs which can run free air tend to have high qts, higher xmax and preferably lower Fs. My budget is fairly meager, so subs like the ID MAX series are probably out.
Anyway, I know that I need to run the sub at about 50% of stated RMS to not have excursion issues. The music I listen to is rock, folowed by more rock. No hip-hop, house, etc. I've listed five subs below that meet the cost criteria and have posted the relative specs for qts, xmax,Fs, and power handling. If anyone has experience with these models and their potential usefullness in an IB set up, I'd appreciate your feedback. If I've missed a brand that you think works best (bearing in mind my budget), I'd welcome that as well. Thanks.
Eclipse SW 4000
Qts: 0.6
Fs: 38Hz
xmax (one way) 12mm
250 rms/ 750 max
Kicker C10
Qts: 0.516
Fs: 29.4 Hz
xmax (one way): 9.76mm
150 rms/ 300 max
Alpine R
Qts:0.5
Fs: 31Hz
xmax (one way): 18.1mm
500 RMS/ 1500 max
Earthquake Tremor X
Qts: 0.532
Fs: 33.7 Hz
xmax (one way): 25mm
500 RMS/ 1000 max
Boston Acoustic G1
Qts: 0.58
Fs: 30HZ
xmax (one way): 10.5mm
200 rms
ED 11k.v2
Qts: 28
Fs: 24.8
xmax (one way): 15.1
300 RMS/ 600 max
The ED really confuses me, because it says it's designed for IB, but its Qts and xmax leave it at the low end, especially in the Qts catagory (0.5-0.7 recommended for IB).
Any input would be greatly appreciated. Also, should I get a 4ohm DVC, or SVC; I'm not sure I understand how to effectively wire this set up. Thanks.
Here's where the conundrum starts: The ID says it's good for a 0.5^3 sealed box - even at 4x that number, it's much smaller than my trunk. The eclipse data says that its subs are not recommended for free air usage. I love to get the eclipse (maybe the sw6000 or sw7000), but when the manufacturer tells you not for free air, then what's a guy to do?
People have very nasty thoughts about ED's behavior, so maybe that takes them off the list. If I narrowed it down to three, it looks like it would be BA, Eclipse (if they can be used for IB), or the Alpine. If anyone has used these in a large, sealed box (like 3.0ft^3) I'd love to know how they behaved. Thanks.
shoeless
shoeless
CT
Lakota
