I need some simple circuit design help.
4AGZE4EVER
I need to step down 12ishv dc to 9ish v dc. Any body have a simple way of doing this? I want to hard wire my xm roady and the only thing left is the power. It takes 9v in.
Please help. I know that cars range form 12 to 14.4 v DC but the adapter says 12 v to 9 v.
Just use the cigarette lighter end, leave it on. Dismantle is, solder a positive lead and negative lead on the shit inside... and wire it in to 12v.
Easy as hell...
Or just buy this... you'll get better reception as well. It'll still be FM Modulated...but it will be hardwired. It also includes a female cigaretter lighter end with bare wire leads so you don't have to modify the power lead to hardwire it.
http://www.circuitcity.com/ssm/Delphi-XM-SKYFi-SKYFi2-Radio-FM-Modulator-SA10003-/sem/rpsm/oid/70756/catOid/-14641/rpem/ccd/productDetail.do
Tits!
nG
FM modulation //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
That's the only way to do Satellite Radio unless you buy an aftermarket HU that is Satellite Radio Ready //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
nG
I agree, rather than wasting time fabricating something to drop voltage, use the existing cig lighter and hardwire it to your car. BTW, what car is it?
^^^ But then its is still too high when the car is running. Sure, 2.5 V difference probly wont hurt it, but most circuitry these days will not power on at a voltage much higher then the specified voltage.
If it comes with a cig. lighter attachment that plugs straight into the unit, it can handle typical car voltages meaining it's regulated inside. Hardwire it, but BE SURE TO USE THE FUSE outta the cig. lighter attachment!
You sir are right.
For hardwire dsr's just get the kit posted above when it comes to xm... but if it's sirius just chop the end off.
OK. I will never use FM modulation it blows goats. I am using RCA's to go to a aux-in.
on to other issues.
I tested the adapter it outputs 6 volt constant. This is regardless if the car is on (14ish) or off (12ish.) I openned it up and there is farely complicated looking circuit inside(at least to me.) I am just going to solder leads to the inside of it where it would normally plug in to the cigarete lighter. I'll take some pics tonight of the inside.
4AGZE4EVER
4AGZE4EVER
San Diego
4AGZE4EVER
Mike Mccabe
