I need some help
Thats a pretty good looking setup. Deff see if ur bro can get ya an amp that will do about 500watts rms @ 1ohm since ur subs will have dual 4 ohm voice coils. Then you can wire them parallel (hot to hot, gnd to gnd) to put a 1 ohm load to the amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what is better 2 or 4 ohm?
It depends on a lot of things. in your case, you have 2 dual voice coil subwoofers that are 4ohms each which means you have 4-4 ohm voice coils. When you wire the hot from each vc to the next one and then to the amp, it will give u a one ohm load to the amp. Since each od these subs can handle 250 watts, you need a 500 watt amp to match it. (250 + 250). I would spend some time on here looking up some things like that. i have book marked some helpful site and i will send them to you as soon as i get home. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what amp you think?
Anything that can do 500 watts at one ohm. Also look at the RMS for subs, speakes, and amps. The max rating is just for marketing corps to sucker punch someone who doesnt noe ne better.
EDIT:
An example would be the RD 500.1 i mentioned earlier. you can look at their website at rdaudio.net Steve Miller is the owner of RD and he is also on this forum. if you can find him on here then im sure you can get one for pretty cheap.
ok thanks very much, now i still want t here the music will these speakers be able to do the job or should i upgrade to better ones?
look in the classifieds here, u can do alot better for the same price. For realzz
those rockfords **** and wont get loud at all or even sound good, they are crap.
And you will need a amp to power ur speakers, if u want them to keep up with ur sub.
grizzlypaugh
grizzlypaugh
OR
GMCJimmyslt2000
Mike Mccabe
