I need some help
There should be a lever of some sort to push down and the clip will pop out. If you're not talking about the harness at the actual speaker, then what you may mean is that the wire lead is too tight to get any slack on it to release it. There should be a clip downstream of the speaker that is wrapped around the wire and connect to a hole in the rear deck possibly, acting as a support. This should just pull out of the metal deck to give you the required slack to unclip the speaker.
Kdubs20
Kdubs20
rochester hills mi
eengrms
