I need some help with my next box.....
Grinder1989
Sundown Audio Dealer
Here is what I have to work with.
48" long
23" tall
14" deep
Sub and port will be firing up.
Port area must be 70 square inches
I'm looking around 5 cubic feet after sub displacement but I have no idea what the displacement would be so we'll say the equivalent of an MT.
I do not have any specs on the sub but I'd like it tuned anywhere between 28hz-35hz.
I have tried to design this myself but I'm not sure what to do about port area and all that. Oh and the sub is the 15" Nightshade Prototype. Thanks for the help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the port area is measured at the opening, assuming that the port is the same width/height throughout the port. the port area remains the same regardless of the length, you just go longer or shorter to get the tuning you want
But does the port volume have an impact on the sound? I know the tuning can be changed with it but I wasn't sure if port volume affect anything else.
The port AREA can have dramatic effects on the sound, too little area and you can have lots of port noise = bad. Also length can have equally dramatic effects due to the tuning differences.
The best advice i can give you is to have one of the more reputable box designers model you a box based on your dimensions, port and space requirements. A properly designed box can be priceless, the best built box in the world can be crap if the design is flawed
Yea I was looking for that but, my specs are as follows on the box I just designed:
square port area = 86
square port volume = 3526
square port volume displaced = 3551.125
Box volume = 5.177 cubic feet
Its tuned @ ~30
not familiar with the sub at all, but the box looks nice and loud, should hit the lows pretty good. Do you know what the Fs is of the nightshade?
Not a clue. I wish I could find the conversation I had with Jake about it. I asked him the specs and he said "loud" //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif. But he never tested it I guess.
Up. OK so I have the plans and I'm going to pick up the wood in a week or two. I have an assload of drywall screws so the only other thing is the glue. I've used liquid nails in the past and never had any problems but I'm sure there are better things out there. What glue do you guys use?
Grinder1989
Grinder1989
Akron, OH
Grinder1989
