I need help
El NICA
I have a RF 501x amp in the car with two DVC 600watts boss subs, everything was working fine, but now when I raise the volume the amp shuts down for a while. I don't Know what to do. Do you Know what might be happening???. It's my amp broke or something
Seems like some auto-protect on the amp is kicking in... try setting the gain to a lower value and check if you are using the right input for the amp (ie don't connect a high-signal to a low-input)
Also check if the amp and subs ohm-rating match...
sounds like you wired the subs to a lower resistance than the amp can take.
are the subs DVC or SVC and whats the coil resistance (4 ohm? 2 ohm?)
if it ends up lower than 2 ohm total for all voice coils, i bet its the problem.
El NICA
El NICA
Kenosha
El NICA
