ok check it out..........on the subs what u want to do is wire the positive on voice coil 1 to the positive on voice coil 2....and do the same with the negative.......Wire negative on voice coil 1 to the negative on voice coil 2.....do the same with the other sub...
now on sub A connect a wire from the positive to the positive of the amp and aslo do the same with the negative ....now repeat the same thing with sub B....this will give you a 1ohm load.
now the jbl amp has inputs for two subs..it may look like a two channel amp but in reality its internally bridged, so its really one channel....they set it up that way so its easy to hook up.
