i need help with my woofers
Dude people aren't helping you cause you need to give more info on those subs:) here let me help u out find this info out;)
*What that sub does Rms?
*what the impedance can be wired up u said 4 ohm but make sure ?
rms is 350 and 4 ohm single voice coil like i said im not good with this stuff so give me some slack i have one more question would this amp work for these woofers its a MTX MXA4002 2-Channel 400 Watt if i bridge them would i be getting 400 watts for each sub here the specs
Power output: 100 watts RMS x 2 channels at 4 ohms
Signal-to-noise ratio: 80 dBA
Additional Power Output: 200 watts RMS x 2 channels at 2 ohms, 400 watts RMS x 1 channel bridged at 4 ohms
Frequency response: 0 Hz to 20 kHz
Maximum input signal: 5V
Maximum sensitivity: 100Mv
Dimensions: 4.37 inches x 9.72 inches x 2.5 inches
I have an MXA4002. It does a little more than 400. If you get that each sub would get about 120 ish watts. They're starting to be hard to get though. Bridging a two channel amps takes two channels so you would only be able to hook up one sub.
xxxpower
more money more problems
xxxpower
orange grove tx.
Steven206Seattl
