i need help with 4 15 inch subs for a freind
jose_hdz646
ima install four 15s for my freiend for competitions now you guys may or may not know about this brand its audiopipe and down here in texas its getting big and my freinds is stuck on audiopipe, so he has an old mercedes benz a 82 240d its old and hes gonna take the back seats out so i can build him a tall box for four 15s he wants me told me to basicly find prices and amps to go well ima custumize everything for him and i need a little help from people the subs are 1000 watts rms and he wants four so i need 4000 watts rms but audio pipe dont make 2000 watt rms amps to run two subs so my idea is to, tell him to get 4 1000 watt rms amps and put one to each subs he has an upgraded alt. and a deepcell batt and a huge batt. in the trunck know can i do that many amp in his trunk. and under the hood will i need a battery isolator or is that optional? and if i run one amp to all each sub can i have all subs in one chamber ported and just even them all out and have them all to i dont know... maby like an eq to control them all at once? do they make anything like that?
Stuck on audiopop's huh?? Well AP makes a 1500watt amp a 1800watt amp a 3000watt amp and a 3500watt amp. So you have many choices. I would not buy anything from audiopop other then there new 3500 as its looks like it is of some quality. All others seem to do rated but IDK I have seen a lot of them go poof for no reason at all so there quality has to come into question. No need for a batt iso as it is unnecessary. Also, you can run all 4 15's in a shared chamber with no issue I assume he is going ported. I hope he has ALOT of run cause its going to be a massive box. Might wanna think about getting a 3rd batt and getting a new set of stiffer shocks for the car. Cause you are looking at 300-500 extra pounds in the rear....
If you’re stuck on the pop's I would get 2 1800's or 1 3500 both will provide all the power he needs. Again I would only get the 3500.
jose_hdz646
jose_hdz646
harlingen tx
theMessenjah44
