I need help TONIGHT!
lephatrabbit454
ny
Hey guys. im upset . grr
lol my buddy fried my amp today hookin it up to his system.
long story short im goin to get a new one tomorow as im not goin a weekend without it. im running 2 JL W0 12's in a bandpass box. i used to have a BOSS 300x2 doin the job but i need a new amp now. ive got 250 bucks. i need to spend as little of it as possible. lemme know tonight cuz im goin tomorow. thanks in advance guys!
look for somethin on ebay.. youll get a better deal.. but youll have to wait the period. it will be worth it instead of getting another crappy flea market amp like boss.
well all 3 of those amps put out their rated power....unlike the boss amp....not sure if your w0's hanlde 300w rms tho......also i'd suggest a diff. box if your looking for any kind of sq at all......anyways...enjoy
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Available Configurations: 4 ohm or 8 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 1.00-1.75 cu.ft. (28.3-49.5 liters)
Ported Enclosure Range: 1.75-2.75 cu.ft. (49.5-78.0 liters)
VRC™ Technology: YES
I have 2 of these. they are JL w0
Well, that didn't answer Woodmister's ohm rating question. Do you have the 4 ohm or 8 ohm?
ok, so you need an amp that does 250watts RMS and is 2ohms, humm...
1) USX 600D --> http://www.thezeb.com/caraudio/us_acoustics.html
2) JBL 300.1 --> http://www.ikesound.com/Prod_Details.asp?Prod_Id=148
3) Profile 600M --> http://www.ikesound.com/Prod_Details.asp?Prod_Id=148
With all these amps, keep the gain down...
2x 4ohm subs can be wired like is to get a 2ohm load (which is used more)
lephatrabbit454
lephatrabbit454
ny
bri487
michigan born
    May 14, 2026
michigan born
    May 14, 2026
